Español
Support
Best in Class - The Customer Respect GroupThe Year's Ten Best Web Support Sites
in
Search
Managing Parental Controls
Many parents are concerned about their children watching unsuitable programming or having access to Pay-Per-View content.
To offer parents more control over the programming and content their children can access, Verizon offers FiOS TV Parental Controls that enables parents to:
  • Selectively block programming by channel or rating.
  • Selectively block Pay-Per-View and On Demand purchases.
  • Set up two different user-defined PINs (one for purchases and one to block programs.)
  • Hide adult programming from the TV Listings.
  • Block access to social networking Widgets for Facebook and Twitter.
To set up and use Parental Controls:
  1. Press the Menu button on your remote.
    The Main Menu is displayed on your TV screen.
  2. Using the arrow buttons on your remote, highlight Settings and press OK/Select
    Note: Depending on your remote control, you'll need to press either the OK or Select button to make a selection.
  3. Select Parental Controls and press OK/Select.
  4. Create your own 4-digit PIN. You'll then need to retype your PIN to confirm your selection.
  5. To block or unblock programming, highlight a parental control setting and press OK/Select.
    Important: Blocking any rating (such as TV-14) also automatically blocks all higher (more restrictive) ratings such as TV-MA.
  6. After setting your parental controls, highlight Enable Parental Controls, and select On then press OK/Select.
    A green checkmark indicates that Parental Controls are turned on.
    To Disable parental controls, highlight Enable Parental Controls and select Off then press OK/Select.
My Preferences
TV: FiOS TV
Ask Verizon
Repair Status
To view, update or cancel your repair request enter your phone or data line number.
red arrowCheck with user name
Check Status
Order Status
View order progress, connection date and more
red arrow Check Order Status
