Español
Support
Best in Class - The Customer Respect GroupThe Year's Ten Best Web Support Sites
in
Search
How to lock or unlock channels
To lock or unlock channels:
  1. Press the Menu button on your remote control.
  2. Select Settings.
  3. Select Parental Controls.
  4. Enter your PIN.
    To lock or unlock all channels:
    Select Lock All or Unlock All and press OK.
    To lock or unlock specific channels:
    Select Channel List and scroll through the channels. You can lock any channel that is currently in an unlocked state by pressing OK on that channel. A padlock icon appears indicating the channel is now locked.
    Similarly, you can unlock a channel by scrolling to it and pressing OK. The padlock icon disappears indicating the channel can now be viewed.
My Preferences
Internet: Dial-Up Internet
TV: FiOS TV
Ask Verizon
Repair Status
To view, update or cancel your repair request enter your phone or data line number.
red arrowCheck with user name
Check Status
Order Status
View order progress, connection date and more
red arrow Check Order Status
